LR2 Sunroon opens but no closey
Old Oct 21, 2008 | 01:02 AM
discosmurphy's Avatar
Default LR2 Sunroon opens but no closey
We have a 2002 LR2 with 58K milesthat has a sun/moon roof that opens but doesn't close. It open right now even. I press the button to close it and I don't hear the motor turn, but if I try to open more (it can't open any more because it's already open all the way) I hear the motor atleast. I've Googled and searched many forum with no luck. Is there a Guru out there that can help?
Old Oct 21, 2008 | 03:10 AM
Urban Panzer's Avatar
Default RE: LR2 Sunroon opens but no closey
Remove the switch panel from above your head (it prizes out carefully), then swap the 2 sunroof switches over, it could be just a duff switch, as I "assume" 1 roof works fine the other only goes one way.
Old Oct 21, 2008 | 08:36 AM
First of all, you don't have a 2002 LR2, you have a 2002 D2.
You may want to use an allen wrench to manually close the roof through the rectangular shaped access opening in the plastic trim.
Old Oct 22, 2008 | 12:05 AM
Thanks everyone. It magically worked today and closed. I'll switch the switches and change my profile.
aarongregor
Mar 24, 2013 10:09 AM
Hurricane Moon
May 1, 2012 06:55 PM
zracin
Nov 3, 2011 12:17 PM
trophy900
Freelander
Nov 30, 2010 11:17 AM
tulsa
Jun 27, 2010 06:01 PM
