LT230 Transfer Box Gaskets
Old Jan 4, 2016 | 05:26 PM
june82000's Avatar
Default LT230 Transfer Box Gaskets
Hi All,
I have a '95 D1. Is it recommeded to use the gaskets when re-sealing the LT230 Transfer Box; or simply use sealer such as I heard "the right stuff?
Old Jan 4, 2016 | 05:48 PM
Alex_M's Avatar
The gasket set is pretty cheap, so you could use those for simplicity sake. Even if you did, I'd still coat the gaskets in RTV before installing them. Lucky 8 has the gaskets as a set.
Old Jan 4, 2016 | 06:47 PM
jafir's Avatar
The gasket sets come with the shaft seals too. You cannot use sealer in place of those.
Old Jan 4, 2016 | 07:25 PM
june82000's Avatar
Hi all, thanks for the input. I checked the manual and it just mentions using the RTV which I've heard permeated 'the right stuff' is pretty good. My question for the main shaft seals is how much is involved in replacing them? Right now I have the box out with the parking brake drum removed and I think the output gear removed as well. I know for sure I need to replace the felt washers. Also, the viton main seals appear to be the ones to use if I go to the trouble of replacing them.
mikesmif
Dec 8, 2017 02:18 AM
xb70valkarye
Sep 9, 2009 04:46 PM
ajh
Oct 23, 2006 09:42 PM
extremetoy1
Jul 14, 2006 12:28 PM
lugo35
Apr 21, 2005 05:03 PM
