Lug Nut Issue
Old Jul 27, 2023 | 04:10 PM
dansohner's Avatar
Default Lug Nut Issue
Hi all,
Rotated my tires and noticed that I accidentally used the nuts from the spare carrier on the wheels. I know they are different sizes and I should have known better.
I haven't removed them yet, but is this a sure fire way to strip the threads? Everything I have read says yes, but checking once again to see if anyone has had this issue.
Thanks!
Old Jul 27, 2023 | 05:41 PM
Richard Gallant's Avatar
@dansohner they are the same size on mine
Old Jul 27, 2023 | 11:09 PM
Harvlr's Avatar
Mine too.
Old Jul 28, 2023 | 08:06 AM
mollusc's Avatar
The threads are the same size -- it's the thread depth that's different. The studs on the spare mount are longer than the wheel studs, so the nuts for the spare are bored and threaded all the way through. The wheel lugs are a blind hole. So using the spare lugs on the wheels is not a problem.
If you try to use the wheel lugs on the spare, they will bottom out and not hold the wheel tight.
Old Jul 28, 2023 | 12:29 PM
Harvlr's Avatar
Interesting. I’m not at all sure that mine are in their original positions. None of mine are bottomed out.
Old Jul 28, 2023 | 11:08 PM
Same on mine I replaced the locking nut on the spare with a lug nut I grabbed at a wrecker works fine.
Drubie22
Sep 22, 2014 02:04 PM
Greenhead
Jan 25, 2014 04:09 PM
geek_IM
Jan 10, 2011 09:49 AM
NGOphotographer
Jun 23, 2009 02:02 PM
AK Rover
May 22, 2009 11:38 AM
