Minor PS leak
Old Dec 19, 2010 | 07:06 PM
buick215's Avatar
Default Minor PS leak
I recently noticed that I have a minor power steering leak. I degreased the area and can't really find the leak. The PS fluid in the reservoir tank went down about a 1/4 inch this last month. I was thinking about using a stop leak additive. I am not sure weather to try Lucas or White Shepherd. I will also like to know how much to use, I have read that too much can cause even more problems. Thanks for any help that you can give me.
Old Dec 19, 2010 | 07:18 PM
I would use a power steering fluid with stop leak built in, just use it to top off the system until the leak stops or the bottle is gone.
If it continues then explore a repair.
Old Dec 19, 2010 | 07:19 PM
I have had great luck with Valvoline fluids with stop leak.
Old Dec 19, 2010 | 07:32 PM
buick215's Avatar
Thanks for the advice Spike, by the way I just checked the level and it is between the full level and empty so I am assuming that the leak has gotten worse in the past two days.
Old Dec 20, 2010 | 08:44 AM
Newscotlander's Avatar
I had the same problem about a month ago. The local shop told me it was the seal in the steering box. Not. Ended up being the pump. I replaced it myself. Got the pump from A-B and it took me about 3 hours. It would have taken less time if I had removed the fan.
Old Dec 20, 2010 | 09:17 AM
Buick
I had a leak at my pump and used the White Shephers P/S stop leak as per the directions and it works like a charm as long as you drive and or idle the engine for 2 hours have installing the additive on "NEW" p/s fluid.
Lucas, if you read the label, which most don't is a stop leak for internal leaks, not external .
Order some Whitesheperd, you will like the results.
Old Dec 20, 2010 | 01:43 PM
buick215's Avatar
Thanks for the help. I am going to try the stop leak since the leak seems to be minor. Hopefully I won't have to change the pump or hoses.
Old Dec 20, 2010 | 03:39 PM
Make sure you flush out the old fluid before install the stop leak.
Old Dec 20, 2010 | 04:24 PM
buick215's Avatar
Will do, how much of the white shepherd should I use, again thanks.
rodrick smith
Nov 2, 2007 03:17 PM
Panama Jack
Oct 16, 2007 04:18 AM
Disco C
Aug 8, 2007 08:25 AM
willlane
Jun 20, 2007 10:57 AM
dma3
Apr 2, 2005 02:55 AM
