misfire
Old May 6, 2010 | 10:57 PM
aemnky606's Avatar
Default misfire
OK I have a cylinder 7 misfire code. Have E3 plugs, mm wires, and just put new o2's in. Do i need a new injector?
Thanks,
Walter
Old May 7, 2010 | 06:33 AM
hilltoppersx's Avatar
what brand and size wires? what is the 4 digit code you are getting?
Old May 7, 2010 | 10:01 AM
Why are you guessing? Why an injector, do you have an injector fault code, 407?
What code number do you have, have you pulled and inspected you plug and wire, who's did you use?
Old May 7, 2010 | 10:14 AM
okdiscoguy's Avatar
I will add that I believe Spike ran E3's for a bit and took them out because he was mis-firing.
What size wires again? you just put mm, no number
Old May 7, 2010 | 10:16 AM
NiteTrain's Avatar
swap plug/wire to another cylinder and see what happens
Old May 8, 2010 | 07:17 PM
aemnky606's Avatar
ok guys, the wires are 8mm from apex performance and the code is P0307.
Old May 8, 2010 | 07:28 PM
Nope, was not mis fires from those plugs, there were no codes at all, she just idled bad when hot, but no codes.
Pulled them and put in $1 copper plugs and she ran like a champ.
Then I went back to Iridiums and she still runs like a champ.
My wife's Volvo loves those E3 plugs, so does my lawnmower and snowblower.
Gromeo
Jan 24, 2013 03:41 PM
ta981
Jun 10, 2006 02:15 PM
Scott2747
Feb 8, 2006 12:11 AM
cottonpatchweims
Aug 15, 2005 11:19 PM
tbesselman
Jun 1, 2005 01:54 PM
