Misfire Trouble
Old Sep 13, 2018 | 09:12 AM
Dave03S's Avatar
If you got coolant crud that probably means you have Dexcool... Pink coolant? If so flush and switch to the green stuff.
Old Sep 13, 2018 | 09:52 AM
jastutte's Avatar
Originally Posted by nmacej
Just had a chance to take a closer look. The coolant is definitely coming from the throttle body gasket Whew (I think). I mean... much better than another head job/motor. But still the misfire question remains. I'll probably just swap out the plugs and wires, but I hear it's a PITA. Should I spring for coils too while I'm doing it, or is it not as bad as everyone says to circle back to those if needed?
on my '04 i had coolant leaking from the throttle body heater gasket. the coolant would run back towards the driver and drip onto the plug for the driver's side front O2 sensor. it caused some corrosion in the O2 sensor plug, which in turn caused rough running and some misfires. i fixed the throttle body heater gasket and cleaned the O2 sensor plug, both male and female ends, and the issues went away.
Old Sep 13, 2018 | 02:53 PM
nmacej's Avatar
Pulled the plug/boot. cleaned it up and so far, no misfires. Hopefully the coolant didn't mess up the wire too bad, and I got out of this one cheap. I tightened the bolts (not that they were loose), and will keep an eye on the coolant until I get the kit in Monday. Thanks for all your help guys! What a relief! And yeah, Dave, definitely need the heater up here. Good luck with Flo! Hope you and yours are safe.
Old Sep 14, 2018 | 08:25 AM
nmacej's Avatar
No Dexcool. By crud, I just mean the crystallized glycol mess. Like the stuff that makes pilling coolant hoses so fun sometimes.
Old Sep 14, 2018 | 08:32 AM
nmacej's Avatar
Good call. I'll check the O2 today. The cylinder 3 bood was definitely effected, effected, but couldn't hurt to take a look at both.
humroot
Jul 22, 2019 06:33 PM
andrewgib
May 20, 2019 08:57 AM
zuke
Apr 12, 2018 10:53 PM
acamato
Aug 23, 2016 08:23 PM
Effie1959
May 28, 2013 06:18 PM
