Missfire and oil burn
Old Sep 10, 2007 | 04:52 PM
sailorcolin's Avatar
Default Missfire and oil burn
This morning i started my disco one. I noticed it was not running smooth so i went to the exhause to see if it was missfireing, it was and also buring oil. Strangely yesterday it was running fine. I went to an auto parts store to get the check engine light readand it said that cylinder multiple cylinders and cylinder 2 were misfireing. I can't seem to fix it with the common causes like loose spark plug wires. What can I do and why would it burn oil over night. By the way it only has 101543 miles on it and is a 1997.
Old Sep 10, 2007 | 05:55 PM
Default RE: Missfire and oil burn
I wouldn't worry about burning oil. How old are your plugs and wires. You might want to pull the plugs, one at a time and check and see what hole if any is oil fouled.
Old Sep 10, 2007 | 08:28 PM
I changed the wires to day and it runs alot better but ine cylinder is still misfireing to where unburnt fule is comming out of the tail pipe. I am going to change the wires tomorrow. Thanks for the help!
Old Sep 11, 2007 | 08:00 AM
ORIGINAL: sailorcolin
I am confused by your last post, what did you change today and what tomorrow? What brand of plugs and wires are you planning on using?
errose2002
Jul 21, 2011 04:40 PM
briandtn
May 5, 2010 06:59 AM
IDAHODISCO
Sep 17, 2009 08:54 PM
tsuami1
Aug 10, 2009 08:48 PM
doeboy
Aug 8, 2005 11:56 AM
