The moment of truth...
Old Sep 18, 2011 | 07:53 PM
sruff's Avatar
Default The moment of truth...
2001 disco motor replacement due to cracked sleeve. Purchased salvage motor, posed a few questions here (thank you all by the way) and tonight was the night... everything plugged in and all clamps tight... connected the battery and... wait for it.... wait for it..... it started.
The problem.
It runs very rough. Yes I check and double checked the spark plug wires, but it still sounds as though it needs timed or one of the cylinders is not firing correctly. any ideas?
2001 DII 120K
1992 BMW 213K
2008 Acura TSX 32K
1975 MG Midget 65K
Old Sep 18, 2011 | 08:02 PM
In no particular order -
Codes?
Data reading scanner shows ignition advance changing under load, etc.?
Vac leak
Fuel Pressure regulator
VSS disconnected / bad (while underway)
Coil(s)
plugs and wires
injector not working on one or more cylinders (assumes you did not change injectors of donor motor)
But compared to what you just accomplished, this should be a cake walk.
Old Sep 18, 2011 | 09:49 PM
atancreti's Avatar
Codes would be a big thing. If its not firing right then it should let you know right away. Otherwise it could be one of many things listed above....
Old Sep 24, 2011 | 12:53 PM
sruff's Avatar
Default Weekend Warrior
Ok,
Any insight on purchasing a code scanner? It doesn't run well enough to try to make it to a local shop... nobody rents one. Help is appreciated.
The dang thing starts (running on several cylindars), and the problem is NOT the wiring from coil to plugs... I checked and re-checked several times.
Thanks.
Sam
Old Sep 24, 2011 | 01:57 PM
Go to Wal-Mart, they sell a nice scanner for about $80.
AutoZone sells a cheap one for around $30.
Old Sep 24, 2011 | 05:38 PM
humroot's Avatar
Did you double check all the electrical plugs? I ask because I forgot to plug in the plug behind the intake and it ran like crap after I did my heads.
Old Sep 24, 2011 | 09:42 PM
sruff's Avatar
Default I've got the codes...
Thanks for all your help. Here are the codes (please translate into: "Do this" for me...)
P1590
p1300
p0305
p0307
p1319
p0560
p1536
p1668
It looks like a lot... I hope that several quick fixes take care of all of them...
Thanks again,
Sam
Old Sep 24, 2011 | 10:02 PM
1590 - IACV
1300 - random misfire
0305 - misfire #5 cylinder
0307 - misfire #7 cylinder (wires swapped?)
1319 ?
0560 - battery volts low
1536 ?
1668 - immobilizer issue (I bet oringinal alarm is really pissed off because somebody stole the whole damn engine !)
Old Sep 24, 2011 | 10:03 PM
hallfleming's Avatar
Code info:
Land Rover Discovery II: Proprietary OBDII Codes > Northwest Overland Society > Most Recent
Old Sep 24, 2011 | 10:11 PM
Have seen another reference that 0560 is too many codes in memeory, reset codes to clear.; 1319 is misfire with low fuel; 1536 is AC clutch related. So start with plugs 5 & 7 wiring check, check battery volts just to be sure. Clear and start again. That immobilizer code could be a wire unplugged fom a module.
