Motor Mount Install
Old Apr 3, 2010 | 07:51 PM
vandev's Avatar
Post Motor Mount Install
I am changing my broken motor mounts today on my 2004 Discovery. I am taking pictures and documenting for a how to. I will post pictures and instructions tomorrow. So far pretty strait forward on the passenger side that i did. The drivers side is another story as the top bolt is nearly imossible to access. You have to use a open end wrench as a socket does not fit on the top nut and can make only inch turns. I have had to make a pretty animated tool combination's to get the nuts off the mounts. To lift the motor up is really easy with a floor jack and a bunch of 2x4 pieces stacked about 4 high. You'll see. I will show all tools i used also.
Thanks Chris
Old Apr 4, 2010 | 11:35 AM
vandev's Avatar
Default wont start
Well, i finished changing out my motor mounts. I went to start and it just turns over and wount start. Emergency lights are flashing and need to dissconnect neg terminal to make them stop flashing. Switch on dash does not turn them off. Any ideas?
Thanks and Happy Easter.... Chris
Old Apr 4, 2010 | 12:27 PM
lipadj46's Avatar
Press the inertia switch a few times, big black button under the hood on the back firewall
Old Apr 4, 2010 | 02:19 PM
vandev's Avatar
Thumbs up thanks
That was it a couple pushes and bingo... It looks as if mine is comming loose off the firewall. I will be fixing or picking up a new one.
will post later after i organize pictures on a how to for engine mounts.
Thanks Chris
Old Apr 4, 2010 | 07:33 PM
lipadj46's Avatar
Cool I have to OEM motor mounts ready to go and now that the weather is nice I'm running out of excuses.
Old Apr 4, 2010 | 08:16 PM
vandev's Avatar
Thumbs up instructions
I should have finished by morning. I am uplaoding my pictures i took from my iphone and will upload with instructions. Keep in mind the drivers side mount will make you see red as to how dumb the idiot who designed this mount could actually hold a job much less get one. A real F**&^% idiot. Plan on a full day because of this one mount. I think it's a 4 to 5 hour job at the dealer. Also take note that i stress be carfull as it's a strait forward job but remember you have a engine jacked up and fiddeling with these mounts and placement of you fingers needs carfull attention. I had no problems as i listen to every noise and pay attention to where my fingers are but doing this could result in loosing fingers. "Be very carfull and trust nothing and you should be ok"... I will elaborate in my instructions tomorrow,
Thanks Chris
Old Apr 4, 2010 | 08:36 PM
lipadj46's Avatar
I've done my head gaskets, front cover and oil pan gasket, a couple hubs, brakes, suspensions etc. etc. so this truck has tsught me the meaning of patience
terryth
Sep 14, 2020 08:39 AM
rovernoob
Feb 16, 2015 10:44 PM
khuds308
May 13, 2013 09:48 PM
ebg18t
May 28, 2012 08:57 PM
rickm
Jul 31, 2009 09:26 AM
