Motor oil in the South
Old May 23, 2023 | 11:13 AM
cappedup's Avatar
Default Motor oil in the South
I’m due an oil change.
Currently has 15/40. Car is usually in New York.
Since sorting out a load of vibrations and rumblings, rear bearings, feathered tires, I can actually hear my engine.
I think I’m detecting some cam noise. Very feint.
It’s cam side of things because it seems half the rpm of engine. I want to protect that situation as much as possible.
I’m in South Carolina for the year, what would be a recommended weight for the summer?
Old May 23, 2023 | 11:20 AM
matt3502's Avatar
You can keep running 15-40. My D2 spends a fair amount of time in SC and I have never changed out my 15-40. Car resides in Fairfield County, CT.
Old May 23, 2023 | 05:49 PM
cappedup's Avatar
ok. Solid. Appreciate it.
Old May 24, 2023 | 12:52 PM
NVDiscovery's Avatar
I use Mobil 1 High Mileage 10w40 all year here in South Carolina.
Old May 24, 2023 | 03:03 PM
jastutte's Avatar
i was reading a P38 forum and most of the UK owners run 20w50 in their engines.
same engine as our D2s and considerably cooler climate than the Southern U.S..
Old May 24, 2023 | 03:42 PM
Richard Gallant's Avatar
Oil always going to be a struggle I run Royal Purple 10/40 HPS the Disco is running nice and quiet - other than the exhaust leak.
The Brits run 20/50 in pretty much all versions of the Rover V8, when the engine was designed, single weight oils were common - my oil pressure is good so I do not see any need for any higher than 10/40
Old May 24, 2023 | 07:12 PM
Extinct's Avatar
20W50 is a good choice but not sure worth the cost premium over 15w40 or 10w40
Old May 24, 2023 | 09:52 PM
Alex_M's Avatar
My first D2 I ran 15w40 in the summer and 10w40 in the winter. That was the only D2 I ever had this issue with, but I noticed on cold days in the morning, first start, I'd have a bit of clatter for a few seconds with 15w40. 10w40 resolved that.
All the rest I've run 15w40 year around.
Davis31052
Dec 27, 2017 06:13 PM
Alex_M
May 28, 2015 10:46 PM
Jetswede
Mar 21, 2011 09:08 AM
aarons02
Aug 6, 2010 04:24 AM
Spike555
Jan 12, 2009 10:49 AM
