muffler questions?
atvrdr, thats the exact same set up I have, except with flowmasters. Just cut off the stock tip and reuse it.
alright thanks alot for all the help....last question is i dont really like the look of the pipe coming out the rear side instead could i just extend it to make it come straight out?
because i know if you just leave it it will rust the bottom of the truck so if i extend the pipe should it be okay? or should i just make it come out the side?
i think i might just take the resonator off first and see how it sounds then add a muffler..
also if i go this route do i really need to do any welding?..or can i just get a tight fitting pipe and use a exuast clamp?
thanks soo much
thanks soo much
I actually had a muffler shop did the work, so everything was welded. However, if you want to chop off the resonators temporarily, I don't see why clamps wouldn't work --though, it may start to rattle.
