muffler questions?
Old Jun 29, 2009 | 09:38 PM
Torancis_LR's Avatar
Originally Posted by atvrdr
alright so i would be removing the huge muffler in the middle of the truck which i see and id be replacing it with a dynomax muffler then i take cut the resonator off and just do a pipe going out the side? would this sound nice?
atvrdr, thats the exact same set up I have, except with flowmasters. Just cut off the stock tip and reuse it.
Old Jun 29, 2009 | 09:46 PM
atvrdr's Avatar
alright thanks alot for all the help....last question is i dont really like the look of the pipe coming out the rear side instead could i just extend it to make it come straight out?
because i know if you just leave it it will rust the bottom of the truck so if i extend the pipe should it be okay? or should i just make it come out the side?
i think i might just take the resonator off first and see how it sounds then add a muffler..
also if i go this route do i really need to do any welding?..or can i just get a tight fitting pipe and use a exuast clamp?
thanks soo much
Old Jun 29, 2009 | 10:27 PM
That is really your own preference. I preferably like the stock tips.
I actually had a muffler shop did the work, so everything was welded. However, if you want to chop off the resonators temporarily, I don't see why clamps wouldn't work --though, it may start to rattle.
JKK
Headers, Intake, & Exhaust
13
Sep 17, 2014 01:22 AM
BURover
Feb 1, 2008 04:05 PM
wease206
Jan 8, 2008 02:02 AM
christians1600
Jan 2, 2008 02:05 PM
wease206
Dec 26, 2007 03:44 AM
