Mushy brake pedal...
Old Nov 14, 2011 | 09:06 AM
CEL hard fault codes do not clear them selves, need a scanner. ABS codes will take a 3 amigos scanner or better to clear those codes.
Don't worry about bleeding the module unless you drain it entirely when working on it, then send me your number and I'll walk you thru what to do.
Old Nov 14, 2011 | 10:57 AM
jrm123180's Avatar
I did get air into the ABS as my master cylinder emptied out. I'l PM you my number. Thanks again!
Old Nov 16, 2011 | 08:07 AM
Vifa's Avatar
I live in South GA and there are no LR repair shops for a couple hours. Who would have a scanner that could clear ABS fault codes?
Old Nov 16, 2011 | 09:37 AM
You might have to ease down to Florida (I'm on the coast, and I don't have one).
Old Nov 16, 2011 | 10:33 AM
Sometimes it is a lot easier, faster and cheaper to go buy a $200 3 Amigo Scanner from RSWSOLUTIONS.com check and clear your own codes, fix the problem clear the codes then resell the scanner for $150 to $170 leaving you with about a $40 cost.
asmcmillin
Jul 2, 2023 04:25 PM
binvanna
Oct 30, 2012 12:07 PM
EL GALLO
Apr 21, 2010 10:10 PM
ryanrover
Dec 5, 2007 07:19 PM
Durfee
May 14, 2006 04:16 PM
