my 03 disco is shuts off when I come to a stop
Old Jul 22, 2011 | 09:00 AM
drowssap's Avatar
i'll let you guess first, but who knows how old some of these codes could be?
Old Jul 22, 2011 | 09:38 AM
dgi 07's Avatar
Originally Posted by toclimb
okay guys,
more info: the vehicle has 139,000 miles
here are the codes:
p0171
P1300
P0300
P1171
P0741
P0155
P0135
P0134
P0305
P0303
P0306
P0307
Guessing the last four ( 305, 303, 306, 307) are misfires. The P0171 im guessing those are all "A misfire has been detected" code. The others got me kinda stumped
Old Jul 22, 2011 | 09:48 AM
dgi 07's Avatar
OK....to the OP. I generally dont like doing this but due to the extenuating circumstances presented to us, follow these steps to the letter
1. Clear ALL the codes. If nothing comes back move onto step 2. If codes do come back, record then then report back.
2. Take a 15 mile test drive. Stop at mile marker 7.5 and shut the truck down for 2-5 minutes. then drive the remainder. Go home, have a beer, and check for codes again. Then report back.
Old Jul 22, 2011 | 07:51 PM
toclimb's Avatar
8th Gear
Dgi 07,
I followed your instructions. cleared the codes, did the 15 mile drive and here is what popped when the service engine light came on again.
p0134
p0305
p0171
Old Jul 23, 2011 | 07:33 AM
dgi 07's Avatar
Dgi 07,
p0134
p0305
p0171
Ok a few things. You have multiple issues that i can see. Can you use a multi-meter cause you are gonna need it. Gonna make a tech outta you today.
1. You are gonna need to download the rave manual if you diagnose and wanna fix this .It will make things a helluva lot easier. I think drowssap has the link for it in his sig. Download it.
2. P0305 - #5 cylinder is mifiring. Pull the plug. and the one right next to it. Take a good look at it, compare them and take pictures and post them so we can see. Makes it much easier that way. Inspect it throughly, check the gap between both. if they are the same, check the porcelain. Look for cracks, broken, etc. if still no dice, swap the plug with its neighbour, clear the codes and run the vehicle. Once the light comes back up, read the code again. If it has moved to the cylinder you swapped it to, you have found your problem. Replace ALL your plugs. If it still hasnt moved, check your ignition wire, and swap it with its counterpart on the other bank. Clear the the codes and run it again. If it still hasnt moved, you may need a new ignition coil.
3. If its comparably cleaner than its neighbour, you have a lot of work cut out for you. You will need a compression test, and test for combustion gases in your coolant. Speaking of which, have you been losing coolant? If you test positve for combustion gases in the coolant and the compression test fails, your gonna need another head gasket.
3. P0134 - thas O2 sensor bank 1 no activity detected. Check the O2 sensor on the scan tool while the engine is running. If you see no activity, check your connector for corrosion, wires for cuts, etc. Pull the sensor and inspect it, make sure its clean. If all that is still ok, unplug it and check for voltage at the o2 sensor with the engine running. If its flatlined, change it.
4. P171 - System too lean bank 1. Most likely, exhaust leak. Look for exhaust leaks BEFORE the cats. Have you had any exhaust work done? Make sure your exhaust manifold is tight against the block.
On the flip side of that, could be an intake leak.
You have your work cut out for you. godspeed and good luck.
Cosmic88
Mar 9, 2011 06:53 AM
bladerover
Oct 6, 2009 08:11 PM
Nitro96
Dec 12, 2007 11:46 PM
george99
Jul 12, 2007 06:17 PM
Rover9
Oct 17, 2006 02:18 PM
