My Bad ??
Old Oct 23, 2024 | 11:40 AM
Tomzsix's Avatar
So.....yes , my bad . The next drive line I purchase , I will grease the F*ck out of it . And on the subject , what tube of grease is recommended ??
Old Oct 25, 2024 | 01:11 PM
gecko951's Avatar
Driveline grease....generic red synthetic is what I use but its more about making sure that you are greasing the driveshaft routinely at each oil change.
Old Oct 25, 2024 | 07:05 PM
mln01's Avatar
And thoroughly means pumping grease until fresh grease comes out of all four caps of the u-joints.
Old Oct 26, 2024 | 07:34 AM
The Deputy's Avatar
Originally Posted by Extinct
I remove the driveshaft every oil change and grease everyting including centering bearing. Few things cause catastrophic failures on D2, factory style thermostat and front driveshaft are the main two.
I've always greased mine every-other oil change during normal driving conditions, now if any off-roading or really wet conditions have been encountered...it gets dropped and lubed. But, yes...you have to remove the front shaft from the transfercase and lube the center bearing often...or it will fail. Most people overlook this. Just like not checking the transfercase fluid. If l had a dollar for every person that thought when they filled the transmission it fills the transfercase at the same time...l'd be rich.
zski128
Oct 23, 2020 12:34 PM
blurover
Nov 29, 2013 01:26 PM
nahtanoj
Jun 4, 2012 11:44 AM
malmberg
Sep 9, 2010 01:28 PM
sloppyjoe
Jan 7, 2009 11:05 AM
