My Disco does'nt START
Old Dec 10, 2012 | 04:40 AM
No body's Avatar
Default My Disco does'nt START
This morning the temperature was -10*C and my car does not START. The battery is good but it is impossible to start. Why this happened just in cooled weather. I want to say another fact, previously to happened this, my vehicle was very slow(clumsy) it lost power, and from exhaust issues a very black smoke. How do you think my friends may have pump problems? My engine is with Diesel TD5.
Please help me
Old Dec 10, 2012 | 07:28 AM
lr2001silver's Avatar
Banned
Did you plug your truck in to a electrical plug? Diesel will gel up if it gets to cold.
Will it crank? Any codes?
Old Dec 10, 2012 | 09:46 AM
Does the engine turn over at it's normal speed when you try and start it, do you wait till you glow plugs are hot?
Old Dec 10, 2012 | 10:31 AM
Power to glow plugs?
Old Dec 10, 2012 | 11:29 AM
grandkodiak's Avatar
Diesels don't like the cold to start up in, the cold block steals the heat from ignition. Recommend a plug block heater if youre so equipped. Let the glow plugs or grid heater (not sure what LR diesels have) work a bit before trying to start up. Also, check your fuel filter, you may have ice/water buildup. You should also toss in a bottle of antigel deisel stabilizer that keeps if from gumming up as it gets colder and some types can even displace some of the water in the tank before it gets to the filter if you have particullary bad fuel suppliers
Lastly, don't give up! As a last resort you can try a small spray of starter fluid near the intake before trying to turn it over... but it might jsut come down to turning it until shes warm enough to budge:
https://www.youtube.com/watch?v=CQPe9etTb2E
Old Dec 10, 2012 | 02:10 PM
jfall's Avatar
IN super cold - synthetic oil
If diesel - MUST be plugged in for 4 hours before cranking.
You can get a hose and put hot water on the engine for 10 minutes.
Old Dec 11, 2012 | 02:11 AM
No body's Avatar
I found the problem, the spy lamp flashed on the dashboard, water in fuel filter i changed it, f''>>>ng fuel suppliers. These are the consequences of ex-communist countries.
Thank you my friends for all your support.
Old Dec 11, 2012 | 07:25 AM
Banned
Very good
NoogaRover
Jun 17, 2014 02:21 PM
armyeng
Mar 8, 2011 05:58 PM
pat3d
Dec 19, 2008 03:58 PM
pdolan1
Mar 9, 2008 03:39 PM
jonsimon
Jan 29, 2007 01:55 PM
