My power outlet fuse pops constantly (see photo)
Old Jun 14, 2018 | 06:08 AM
09dewaed's Avatar
Default My power outlet fuse pops constantly (see photo)
It is loose in the center console because the green clip that holds it to the console is broken. When I remove my phone charger it pulls the power outlet out a centimeter or so and I hear the fuse pop. Its a real pain. I don't know why the power outlets' movement has anything to do with a short. Im thinking of swapping the lighter out for a USB plug. what gives with the loose plug causing the fuse to pop?
Old Jun 14, 2018 | 06:45 AM
mollusc's Avatar
The power wire to the back of the socket must be shorting to the case of the socket when it moves around. Shorting causes the fuse to blow.
Old Jun 14, 2018 | 10:27 PM
Saturnine's Avatar
Old Jun 14, 2018 | 11:59 PM
JUKE179r's Avatar
A continuous blown fuse isn’t good.
Get it fixed or replaced ASAP.
Old Jun 15, 2018 | 11:00 AM
Saturnine's Avatar
You could use a dab of silicon to hold the lighter in place or just replace it with a USB plug
09dewaed
Feb 18, 2018 07:49 AM
Toran
Feb 23, 2016 10:08 AM
hankeester
Sep 13, 2012 11:03 AM
cipher982
May 20, 2011 09:54 PM
thisisheaven
Jul 12, 2007 01:03 AM
