My seat adjustment died
I searched this forum to see if anything popped up and if this has happened to anyone else. Apologies if I missed any posts.
2000 D2. I am original owner. My driver seat is stuck in one position only. Fine for me but not for my wife when she drives it. Does anyone have any advice on steps to take to fix it?
Just as info, the passenger seat works just fine.
Thanks in advance.
Thanks in advance.
Thank you very much for the quick reply. I will start there.
These things only make like 9:1 or 9.5:1 compression. There's no reason I can see that you couldn't shave the heads half a dozen times if it's only a couple thou each time. If you wanted to decrease your risk of detonation you could do some work to the combustion chamber to do some smoothing with sandpaper or something. I would check the Piston to valve clearance, but if you're sticking with the stock cam that shouldn't be an issue either. Not sure what the stock ptv clearance is.
Also, I agree that heads done need resurfaced every time. A good straight edge (I've got a machinists straight edge) and feeler gauges can tell you if you're within .002"-.003". OP appears to already know that, but just for anyone else who may wonder through. If they're within spec, just cleannup the whole surface with scotchbrite and carb cleaner. Doesn't have to be perfect.
EDIT: Uhhhhh.... Wrong thread I guess.
Under seat fuse boxes.
Two identical small fuse boxes are located beneath each front seat.
https://fusesdiagram.com/land-rover/...scovery-2.html
