Mysterious A/C Problem
Old Jun 24, 2010 | 09:38 PM
LR03NJ's Avatar
Default Mysterious A/C Problem
My A/C works intermittently. Checked all fuses and blower, all working fine. I found out that if I hit the engine fuse box once, the A/C blower dies and if I hit it again, it turns back on again. Somehow, when driving, it turns off if I hit a bump and I have to look for another bigger bump to turn it back on. Sometimes if I cant see a large bump or puddle for miles and miles I wont have A/C not until I stop and hit the engine fuse box with a screw driver handle. Theres no room to tie a big hammer on top of the fuse box. All fuses are good. I'm tired looking for bumps on the road to turn it back on. Please help!
What could be the problem? Is there something within that fuse box that need to be fixed? Are those yellow relays part of the A/C? Anyway to check this?
Old Jun 25, 2010 | 12:57 AM
'BamaBoy's Avatar
I think one of the relays might be part of the a/c. Look at the inside of the Fuse-Box top cover and it should display what all of the fuses and relays go to.
Old Jun 25, 2010 | 07:00 AM
If not the relay, then you may have a fuse box about to fail on you.
Old Jun 25, 2010 | 08:08 PM
LR03NJ's Avatar
Hi, Cant find which relay is the one for the A/C system. The manual said those are for qualified techs only. Mike, About fuse box. Does it really fail? Never heard fuse box to fail. Whats in there anyway aside from fuses? Thanks again.
Old Jun 26, 2010 | 10:13 AM
1stshift's Avatar
7th Gear
On mine 2000 Disco II if you take the cover off the fuse box under the hood on the paaenger side there were 2 small yellow relay's toward the passenger compartment. The front one is the relay for the A/C, the diagram on the box cover shows a snow flake, push down on it to see if it seats better. I had to move mine in and out a couple times, same with the connection at the pump. Good luck I hope it works.
dpwroe
Sep 4, 2015 11:43 PM
tgwaldop
May 14, 2009 01:28 PM
westminster04
May 13, 2009 09:55 PM
kfox77
May 12, 2009 10:53 AM
DiscOwner
Mar 25, 2005 03:55 PM
