nail in tire...wheel stuck WTF
Well it happened to me.
i never herd of a rim sticking to the hub...but it just happened to me, i noticed i had a nail in my tire...so i took the spare tire off the door and prepared to remove the old rim.....wow....
first...i carry a cross with me all the time in the disco...the lug nuts wouldnt move at all...i even grabbed the stock tire iron and used a 8ft steel pole to use a leverage........i BENT THE TIRE IRON....but the lugnuts came off....
then i tried to kick the **** out of the tire and that didnt work right away....then i put the lug nuts on a bit and dropped the truck down and the rim moved a bit...then i beat the **** out of the ****ing rim with my ****ing foot.......
rim 0
adam 1
to prevent this from happening again...i cleaned up the hub surface and coated the lugnut threads and hub surface with anti-seize.....hopefully that will work..
**** yea
****....i love the bleeping feature
rim 0
adam 1
**** yea
Still up. TSB 10/01/01/NAS: At maintenance intervals or whenever a wheel is removed for repairs, lubricate the wheel-center with a zinc-based anti-seize compound. The antiseize grease should be used for all models on the wheel mounting surface when refitting alloy wheels.
Loctite#39901
Permatex#80208
Loctite#39901
Permatex#80208
and another chapter in in the most frustrating things these idiots have designed.. i remember a while ago my wife had a flat on our 95RR 4.0 near the house and between a couple of big guys and a tow truck driver it took them a hour to get the wheel off. ![Roll Eyes](https://landroverforums.com/forum/images/smilies/Yrp3aj7.png)
funny story though, Chris
I hadn't ever thought about that, Spike. I know you can buy "brake dust shields" at a lot of auto pars stores (large diameter thin plastic discs that fit behind your wheel) to keep brake dust off your wheels. You could get a set of those and cut off all but the hub area to serve the same purpose of the anti-seize.
Minty Barbo
08-18-2013 06:07 AM
