nail in tire...wheel stuck WTF
Old May 24, 2010 | 11:49 PM
03discoman's Avatar
Default nail in tire...wheel stuck WTF
Well it happened to me.
i never herd of a rim sticking to the hub...but it just happened to me, i noticed i had a nail in my tire...so i took the spare tire off the door and prepared to remove the old rim.....wow....
first...i carry a cross with me all the time in the disco...the lug nuts wouldnt move at all...i even grabbed the stock tire iron and used a 8ft steel pole to use a leverage........i BENT THE TIRE IRON....but the lugnuts came off....
then i tried to kick the **** out of the tire and that didnt work right away....then i put the lug nuts on a bit and dropped the truck down and the rim moved a bit...then i beat the **** out of the ****ing rim with my ****ing foot.......
rim 0
adam 1
to prevent this from happening again...i cleaned up the hub surface and coated the lugnut threads and hub surface with anti-seize.....hopefully that will work..
**** yea
****....i love the bleeping feature
Old May 24, 2010 | 11:58 PM
greg409's Avatar
Ain't that something?
I grease mine (hubs/nuts) since several years ago I had to back off the nuts 1 turn and drive around the block with my RR.
(But I worked on them for about a half hr first)LOL
luck,greg
Old May 25, 2010 | 12:00 AM
lordmorpheus's Avatar
There is actually a TSB on lubricating the wheel to hub mating surfaces to prevent the wheel from seizing to the hub. I'll try to locate it tomorrow, as I am busy watching that Top Gear video linked earlier.
Old May 25, 2010 | 12:37 AM
handsome rob's Avatar
That is what happens when you take two different metals and put pressure on them. Add in some corrosion and you have wheels that will be a pain to get off.
Old May 25, 2010 | 01:03 AM
Still up. TSB 10/01/01/NAS: At maintenance intervals or whenever a wheel is removed for repairs, lubricate the wheel-center with a zinc-based anti-seize compound. The antiseize grease should be used for all models on the wheel mounting surface when refitting alloy wheels.
Loctite#39901
Permatex#80208
Old May 25, 2010 | 05:52 AM
vandev's Avatar
Default jeeezzz..
and another chapter in in the most frustrating things these idiots have designed.. i remember a while ago my wife had a flat on our 95RR 4.0 near the house and between a couple of big guys and a tow truck driver it took them a hour to get the wheel off.
funny story though, Chris
Old May 25, 2010 | 08:21 PM
There are plastic wheel spacer thingies that you can buy and they go between the rim and the hub.
They are paper thin but keep this from happening.
I do not know what they are called or where I last saw them, but they are like $15 for a set of 4.
I think I saw them on a RR site.
Old May 25, 2010 | 08:39 PM
I hadn't ever thought about that, Spike. I know you can buy "brake dust shields" at a lot of auto pars stores (large diameter thin plastic discs that fit behind your wheel) to keep brake dust off your wheels. You could get a set of those and cut off all but the hub area to serve the same purpose of the anti-seize.
Old May 25, 2010 | 08:52 PM
http://www.autogeek.net/kwwm.html
Its called a "wheel mate"
ImQuattro
May 1, 2014 08:36 PM
Minty Barbo
Aug 18, 2013 06:07 AM
discoverMT
Feb 17, 2008 08:57 AM
GrnRover
Feb 8, 2007 02:41 AM
cassie11
Aug 31, 2006 01:46 AM
