Nanocom Short. OBD2 + Transmission Issues
Old Feb 21, 2025 | 05:30 PM
Harvlr's Avatar
Water damage to the electronics is why we got the Disco for scrap price. In our case, it leaked into the ECU from the heater fan intake.
Old Mar 7, 2025 | 03:44 PM
rikkd's Avatar
Originally Posted by Externet
Check if there is any bent pins at any of the obd2 wiring plugs.
No bent pins unfortunately.
Old Mar 7, 2025 | 03:45 PM
rikkd's Avatar
I didn't see any moisture or reside it could've left behind.
Old Mar 7, 2025 | 03:47 PM
rikkd's Avatar
Bent pins is a good idea actually, good one Extinct!
But also-- you said water is getting in. Bingo.
The water runs behind all the panels - behind headliner, behind a-pillar and dash, behind kick panels, right onto fuse boxes and BCU’s. You’d almost never know it was there and most people don’t. You can have a small stain on the headliner from the sunroofs or roof rails, but that’s enough indication that there could be over time harness and connector/BCU/Fusebox damage down below especially if the leak and water has been happening for years. I’ve seen it many times on D2’s.
At least 50-60 % of D2’s I see in salvage yards have unusable drivers side fuseboxes from water ingress corrosion, FYI. I pull every one I see in hopes it may be a good spare since they are NLA. It’s not rare. BCU’s far less. 10%-20%? Plastic wire connectors near BCU - more likely.
Good luck, Sounds like you’re well on the hunt to resolution.
I checked the ECU, BCU, and SLABS unit. All looked fine without any moisture or residue. They were all dry and a little dusty. Somehow a small spider managed to get into the BCU was crawling around in there! I haven't checked the TCU yet, but hopefully will this afternoon.
My next step is going to see if Theres any voltage getting to the OBD2 port. I can't think of anything else to try.
Old Mar 15, 2025 | 05:18 PM
rikkd's Avatar
Well the issue was pretty simple. Fuse #20 in the fuseblock under the steering wheel was blown. It should've been a 20amp but for some reason mine had a 15 amp in it. Swapped it out and everything works perfectly! Including the transmission issues.
I can conclude that I'm an idiot and when I checked the fuses, I checked the left side of the terminal for voltage. Not the right side which I should've done.
Old Mar 15, 2025 | 08:52 PM
Harvlr's Avatar
Great news! Thanks for letting us know what it was. And no need to beat yourself up. Troubleshooting can be difficult. Good on you for figuring it out.
Old Mar 15, 2025 | 10:23 PM
rikkd's Avatar
Oh I wasn't beating myself up. I think its funny!
I should note I downloaded and printed out the wiring diagram for the OBD2 port to find where the electricity should've been flowing. F20 label doesn't show what it goes to, but rather just to look it up in the manual.
It goes Battery -> Link 3 (50amp fuse) -> F20 (P101) -> a header (K109)) and then to the diag socket. No clue how or why it impacts the TCU/BCU/ECU etc. If someone know I'd be interested in learning.
I noticed a few other odd things that I don't understand. Such as no voltage going between Link 3 and the wire that goes to F20, despite the circuits working. I could be measuring the wrong thing or not measuring correctly. The green checks means I was able to measure 12V through it. Red X means no voltage coming out. No clue why its that way. But everything is working and I'm not going to mess with it unless I need to.
Icantthinkofagoodusername
Dec 13, 2022 03:58 PM
Haileybop
Dec 16, 2020 11:32 AM
RSPTex
Apr 3, 2016 02:14 AM
guevara42
Oct 12, 2015 09:06 PM
calirover
Freelander
Sep 30, 2008 06:18 PM
