Need help
Old Sep 3, 2022 | 12:08 PM
jandaso's Avatar
Default Need help
We just finished to change the evaporator on the discovery 2 2004. I have some plugs that I never found where to plug them back. I have attached a picture of those items. Also now I have a SRS light on the dashboard. Everything was done personally, no dealer was used just in case I needed to plug a scanner after the job was done. Then that never occurred.
Hope someone can help me figure this out.
Old Sep 3, 2022 | 02:19 PM
Harvlr's Avatar
I don’t think either of those are SRS, but I believe there is an SRS plug above where your picture shows.
Old Sep 9, 2022 | 12:50 PM
longtallsally's Avatar
Did you follow section 82-38 in the Rave? That might give you some clues.
I’m a little disoriented, but is the pic from the driver’s side or passenger? Is the passenger, there are a slew of connectors in there. Did you verify the HVAC works completely correct? Air distribution, AC, ECON, defroster, all that? That seems to be the place I’d start.
EJFrog
Sep 9, 2021 07:37 PM
nicpro
Mar 24, 2020 08:36 PM
mrcataulbee
Oct 28, 2010 05:10 PM
ibizian
Sep 27, 2010 07:22 PM
starcraft
Mar 18, 2008 09:42 PM
