Need help
Need help
My land rover discover 2000 has some issue:-
- SLS warning lamp is On.
- Underneath it has box which makes like something On/Off sound 24 hrs but you can't sleep at night hour because the sound is clear something hammering metal (it works like change over for the electricity when contacting phase to onther phase).
What fault codes are you getting for the SLS light to illuminate?
24 hour hammering noise??? With the ignition key turned off? Open your hood/bonnet and check the IAC valve on the top back part of the engine. Feel it to see if that is the culprit to the hammering/buzzing noise. It's supposed to make a buzzing noise when the ignition key is turned on.
Are your SLS air suspension bags leaking air? It is often the case when the rear suspension 'drops down' overnight.
