Need help
Old Aug 15, 2018 | 03:02 PM
Ahmed Salad's Avatar
Default Need help
My land rover discover 2000 has some issue:-
  1. SLS warning lamp is On.
  2. Underneath it has box which makes like something On/Off sound 24 hrs but you can't sleep at night hour because the sound is clear something hammering metal (it works like change over for the electricity when contacting phase to onther phase).
Old Aug 15, 2018 | 08:26 PM
Welcome to the forum, moved this to the right place so you might get help
Old Aug 16, 2018 | 03:24 AM
JUKE179r's Avatar
What fault codes are you getting for the SLS light to illuminate?
24 hour hammering noise??? With the ignition key turned off? Open your hood/bonnet and check the IAC valve on the top back part of the engine. Feel it to see if that is the culprit to the hammering/buzzing noise. It's supposed to make a buzzing noise when the ignition key is turned on.
Old Aug 16, 2018 | 09:25 AM
abran's Avatar
The box sounds like your SLS compressor. You either need a new one or you need to convert to coil suspension
Old Aug 16, 2018 | 12:27 PM
mollusc's Avatar
To check if it is the compressor for the rear air suspension, try pulling relay #5 from the fuse box under the hood. I believe that fuse #9 is also part of the same system. If the noise stops when you remove either of those parts, there is a fault with your air suspension system.
Old Aug 16, 2018 | 05:57 PM
OffroadFrance's Avatar
X1 ........... agreed. Plenty on Ebay and cheap. Don't forget to clean or replace the air intake filter behind the drivers side rear light it's the most overlooked air filter.
Are your SLS air suspension bags leaking air? It is often the case when the rear suspension 'drops down' overnight.
woodchip2bert
Jul 18, 2018 03:06 AM
rug man
Dec 10, 2015 10:43 AM
cwmoongrove
Apr 25, 2013 04:54 PM
outdoor7or24
May 20, 2012 06:44 PM
Prepilot_3ck
Nov 27, 2006 06:33 PM
