Need help // noise coming from under with video...
Old Dec 29, 2020 | 06:47 PM
GoRoll's Avatar
Default (PROBLEM SOLVED - FRONT DRIVE SHAFT ISSUE with VIDEO)
Update!
Shake and noise is gone after installing the new shaft. Drove the car for 10+ miles.
1. Went up the snow the day before. Only used 4lo twice and briefly (2-5 min) to get out of the situation.
2. The noise started when I was decelerating or braking at slow speed (5-20mph). This was when I got home.
I thought it was the exhaust shield cause it was loose. I just added a clamp cause I didn't want to tear / remove tar to tighten it but it wasn't it.
Here's a video, sounds like it's by the transmission but it only happens during deceleration or slow speed... 5-15mph...
Old Dec 30, 2020 | 01:12 AM
The Deputy's Avatar
I'd check the front driveshaft. Noise seemed more prevalent when you moved camera to front area. But, could be the rubber donut joint at rear...they fail also. If both shafts check out okay, l'd be checking fluids in diffs and trasfer case, possibly pulling drain plugs and checking for foreign objects/metal materials. Could be a C/V joint also, jack it up and spin the wheels.
Old Dec 30, 2020 | 04:33 PM
Extinct's Avatar
Put the transfer case in neutral, see if it still makes the noise. Not a typical disco sound but it does sound like something in the driveshafts. Check everything as stated above.
Old Dec 30, 2020 | 08:35 PM
GoRoll's Avatar
that's what I thought. Where do you guys recommend to buy a new drive shaft or can I even save this one?
Old Dec 31, 2020 | 03:24 AM
The Deputy's Avatar
Bought two of these a few years ago. One has about 40K on it and is on it's third Dll and the other has around 25K ? Greaseable, heavy duty and made in the USA.
https://www.ebay.com/itm/FOR-LAND-RO....c100005.m1851
Like anything, being sure to grease it every service/oil change or after heavy wheeling...is paramount.
Did you verify the shaft was bad yet? The noise that thing is making, l'd surely not be driving it until l found out for sure. It lets loose...and it's eating a hole in you trans and exhaust y-pipe.
Old Dec 31, 2020 | 01:51 PM
SundayFunday's Avatar
Centering ball in the double cardon of drive shaft kinda sounds like..
i had similar noise in a Tom woods only a cpl months old. Took me a while to figure it out. Can you lock transfer case & remove shafts independently to confirm?
Old Jan 4, 2021 | 12:28 PM
GoRoll's Avatar
I haven't got around - it's been a bit chilly to work outside. Damn truck is too tall for the garage.
i will check it out this week when the sun is out.
Thanks
Old Jan 4, 2021 | 12:32 PM
GoRoll's Avatar
I found the front drive shaft for cheap.
https://lucky8llc.com/collections/di...ont-driveshaft
Can you give me more info why, I need a new drive shaft that's greasable anyways so imma pull the trigger to buy a new one.
I will check it out tomorrow what's really making noise, I'll jack all 4 wheels.
Old Jan 5, 2021 | 01:43 AM
JUKE179r's Avatar
+1
About 4 years ago I bought this same heavy duty front driveshaft from the same Milwaukee company and it’s still going strong.
Old Jan 5, 2021 | 02:21 AM
The Deputy's Avatar
The advantage of greaseable shaft is...you can grease it every service, extending its life. This is probably more important if you do any serious off roading, have a lift, live on a dirt road, drive snowy/icy/salty conditions or live/wheel in a desert area. The cardan joint has an eggbeater affect going on as it spins. Normally, if something, a mass, is spinning, the centrifugal force throws objects away from itself. However, with the cardan joint design, the lobes of the joint assembly and design of housing work as an eggbeater and draw dust and dirt back into the joint area, especially the cardan joints inner bearing. So, if you are going to service the driveshaft regularly...because of these conditions mentioned above...get a greaseable shaft. But, if you don't see any of these conditions...or...you are not one to get underneath and drop the cardan joint end of the shaft on every service to grease inner bearing...then just buy a non-serviceable shaft and hope you get another 80K out of it.
