Need help // noise coming from under with video...
Old Jan 5, 2021 | 08:26 AM
whowa004's Avatar
I would not buy the lucky8 shaft. Bought one last summer and it failed on my drive from CO to VA for the holidays, it lasted less than 10k miles...if any sort of lift or any heavy loads I would strongly recommend another option. I have a tom woods on my white d2 (almost 30k on it and that truck gets used hard) and another one on the way to replace the lucky8 shaft.
Old Jan 6, 2021 | 01:53 PM
GoRoll's Avatar
ahhhh too late. I pull the trigger too quick.
Waiting for it but today I pulled the front shaft just to inspect it...
not even sure how to inspect it lol but seems like the middle bearing is super loose.
My plan is to replace it.
Change all fluid.
But here’sa video.
Old Jan 6, 2021 | 02:36 PM
GoRoll's Avatar
Originally Posted by Extinct
Put the transfer case in neutral, see if it still makes the noise. Not a typical disco sound but it does sound like something in the driveshafts. Check everything as stated above.
I did this but I already took the front shaft. I might put it back just to check.
Old Jan 6, 2021 | 07:05 PM
Extinct's Avatar
You can leave it out for the test
Old Jan 6, 2021 | 07:07 PM
GoRoll's Avatar
No noise. but I couldn't move anywhere without the shaft.
Extinct's Avatar
Kinda hard to tell, but I don't think the shaft is your problem. When they go bad they are very loose, like obvious bad.
Old Jan 6, 2021 | 07:09 PM
GoRoll's Avatar
Btw one of the best degreaser. I had a few spots on my driveway and now it’s gone. Going to go under the truck tomorrow and spray this everywhere!
Old Jan 6, 2021 | 10:42 PM
mollusc's Avatar
I don't see what year your truck is, but if it has the locking transfer case you can drive it with only one shaft.
If you have the lockable case, you can activate it even if you don't have the correct lever inside the cabin.
Old Jan 7, 2021 | 12:33 AM
The Deputy's Avatar
The u-joint in the front section of the cardan joint looks froze up. The way you have it laying, when you remove your hand the cardan joint should be dropping under it's own weight, but it looks like it is not. You should be able to move each joint right/left and up/down freely. The discoloration of yoke lobes/ears seems to suggest it might be frozen too.
Old Jan 7, 2021 | 12:59 AM
GoRoll's Avatar
thanks.
I'm changing the shaft and all the fluids next week. Hope that fixes it.
