Need help // noise coming from under with video...
No noise without the shaft means it is not the transfer case or transmission. As stated if you can put the cdl in to the locked position either with the lever in the truck or the nipple under the truck (not running of course if you are under it) it should move without the shaft.
Do you push or pull? I felt something but I couldn't move it.
Also, while I was down there cleaning, found the starter heat shield was loose but I remember there was vibration also when stopping or slowing down.
Still waiting for the shaft and fluids, I'll update everyone if that fixes it.
You got a photo? I’m trying to figure it out. Found a 10mm on top but I couldn’t move it at all.
Post #10 in this thread:
https://landroverforums.com/forum/di...e-chime-88478/
The "nipple" is the piece sticking up towards the front of the unit in that photo, poking through the round cover with three bolts holding it in place.
That is difficult to access. I will just wait tomorrow to install my new shaft and go from there first.
Plan -
Install front shaft to see if any noise. If there's still noise.
Change fluid on both diff. Check again.
Then change fluid on transmission.
