Need help with tranny codes
Old Jul 3, 2011 | 10:31 PM
clayrobinson's Avatar
Default Need help with tranny codes
Been getting the flashing S&M lights and here are the codes that Auto Zone's machine came up with.
P1871
Definition: Transmission mechanical transfer case 4x4 switch circuit failure
P1873
Definition: Automatic transaxle concerns
P0600
Definition: Loss of serial communication link
Explanation: The ECM did not detect communication between the modules
Probable Cause: 1. Shorted sensor or circuit
2. Open or short circuit condition
3. Failed control module
I've had a voltage test run a few times and each time I've gotten a reading either just below or just above 14.
Can anyone provide some guidance? Thanks!
Old Jul 4, 2011 | 08:37 AM
Both those 1800 codes are not Rover codes. What is your tranny doing? Better take it to a good trranny shop and have then tell you what is wrong, not the dealer.
Old Jul 4, 2011 | 12:26 PM
I now see that they are not LR codes. I'm having the age-old issues that come with the flashing S&M lights. Transmission goes into limp mode. There'sw no ryme or reason as to the frequency. Yesterday I drove 150 miles without it happening. Today, I drove it 3 miles and parked for an hour. When I cranked it up, they came on. The P0600 "probable causes" leads me to think that it is a typical electrical issue.
Old Jul 4, 2011 | 03:18 PM
ajmille's Avatar
When my fluid was low I had the flashishing lites, I did a filter and fluid change and it went away.
Old Jul 4, 2011 | 03:19 PM
Along with maybe a low voltage issue. Go get your charging system checked at the local parts store, should be between 13.6 and 14.4 volts.
Old Jul 4, 2011 | 05:38 PM
Rovin4life's Avatar
the 600 is an trans ecu fault. seen a transmission ecu bite the dust intermittently the same way.
it would do it intermittenly and we put a new one in and it solved the problem.
Old Jul 4, 2011 | 06:40 PM
You can get a used trans ecu for like $50 if you shop around alittle.
It is under the drivers seat, 10 min swap.
Worth a shot.
NWROVERS
Mar 10, 2015 03:17 PM
csp
Jul 1, 2013 07:33 AM
buick56
May 15, 2013 06:11 PM
04SSHD
Apr 11, 2012 06:20 PM
BajaXJ92
Dec 3, 2009 07:43 PM
