Need to remove ignition switch
Old Mar 27, 2007 | 03:27 PM
johnkbl's Avatar
Default RE: Need to remove ignition switch
Definitively I am going to try that.... Thanks a lot for your help!
Old Mar 27, 2007 | 04:01 PM
johnkbl's Avatar
Definitively I am going to try that today or tomorrow... Thanks a lot for all your help!
Old Mar 29, 2007 | 04:52 AM
variablecheese's Avatar
4wd High
I actually had someone accidentally snap off my key in my 94 Disco's ignition two days ago. Added to this prob was the fact that I was out off-roading when this occured. I ended up having to remove my ignition switch with a hammer and screwdriver (ouch!) just so I could start it to get back to town! As soon as I can find a wiring diagram, I am going to install an after-market keyed ignition on the dash as a replacement. Ten bucks and I'm back on the trail!
Old Mar 29, 2007 | 10:49 AM
jules's Avatar
4th Gear
I bought my 2001 Disco with half the key in the ignition switch and the other half about to snap.
I got a used switch, key and door handle.
It was actually a pretty simple swap and I did it last night. I was concerned about those shear bolts, but I got them off with some needle nose vice grips. There were three connectors that had to be pulled off. I didn't even disconnect the battery and the total time was less than 1/2 hr. I re-installed the shear bolts using the same vice grip method. I then took the circuit board out of my old remote and put it in the new one.
Presto!!! No more problems.
Old Mar 29, 2007 | 12:50 PM
johnkbl's Avatar
I removed the switch two days ago. I grinded a small line in the top of the bolt, and easily I unscrewed them...... Then, I found a pin in the back of the tube that holds the key cylinder, and saw that someone had been there before because the pinwas glued with epoxy. I had to grind the epoxy and then I easily could remove the cylinder.... It was really easy.
Thanks all for the help!!
wheelgarage
Oct 1, 2011 03:12 PM
caleb
Jan 6, 2010 11:26 AM
hwild77
Dec 17, 2008 02:32 AM
cryptic
Dec 6, 2007 02:32 PM
jaxrvr
Apr 24, 2005 12:01 AM
