need some help with this bell housing
Old Apr 24, 2013 | 07:40 PM
caymandrew's Avatar
Default need some help with this bell housing
While looking at the oil pan for a small leak I have, I notice some sort of large rubber plug half poped out of where it is supposed to be:
I can't find this plug in the rave? There appears to be one on the other side as well. What is it? Whatever it is it's open in a way that would allow water to flow right into my bell housing!!!
Fearing I had a rusty pool inside I opened up the inspection port and it's didn't look good to start:
But once removed there was no more fluid and it looks like this inside:
Is this what would be expected?
Here you can see the light coming through where the plug should be. The one I removed is so mangled it'll not go back in and I need to find a replacement. Any idea on a name? Thanks!
Old Apr 25, 2013 | 07:26 AM
Paul Grant's Avatar
That plug conceals access to the four bolts holding the torque convertor to the flex plate. I don't know what Rover calls it specifically but if you call the dealer or any reputable Rover parts supplier and tell them where it is I'm sure they'll have a replacement for a few dollars.
FrFghtrBRET
Oct 25, 2011 05:40 PM
MarvelVT
Mar 23, 2009 09:53 PM
Dino76
Jan 25, 2009 01:53 PM
mburnett
Jun 4, 2008 04:02 PM
telly
Mar 20, 2007 03:02 PM
