New to LR and have a few COMPLICATED problems I need help with!!
Old Oct 3, 2015 | 01:59 PM
  #21
OffroadFrance's Avatar
Originally Posted by cableguy1979
I purchased a 2002 Discovery II SE7 for my sons first car. It has just about all the usual quarks the LR have or so my research suggest. There are two problems I need help with from someone that knows more about this then I do. I know the LR has been lifted a couple of inches with spacers and the rear driveshaft has been replaced with aftermarket. I believe the front has been too but I don't know (three ujoints). I will provide pictures in the attachment section.
First is the driveshaft. There is a vibration at 55+ MPH and I want to test to see if the front DS is the problem. The way I understand it is the 2002 doesn't have the CDL option so my question is can I still pull the driveshaft and drive without the ability to engage the CDL? I believe the front driveshaft has been replaced and I know the rear has, the rear doesn't have the rotoflex. The front DS looks like its got three brand new Ujoints from diff to Tcase. My son is driving me crazy to fix his first ride. How can I test the front shaft on the 2002?
Second is the AC only works on high and again research tells me it the resistor that has gone bad, I've not actually been able to find where its actually located or what it looks like on the passenger side but I have a good idea but I understand it also has a Final stage resistor and I don't know the difference. I've seen that some people have soldered the resistor off and the new one back on for the fix. I would like to do this option but need some more detail to do it since its a lot cheaper to fix it then replace it.
I'm not sure whether you have the bodyshell jacked up or spring lift but the front driveshaft looks extraordinarily close to the cross member by comparison to mine and if either of the wheels go into droop the shaft will hit the cross member. It may have some rational explanation or the photograph is deceiving.
SinisterMoose
Jun 16, 2015 04:26 PM
Vigo
May 29, 2015 06:55 AM
rmace1
Mar 3, 2012 09:25 AM
bcolins
Aug 27, 2008 01:30 PM
briman42487
Oct 14, 2007 09:47 AM
