New Rover Owner
Old Feb 20, 2013 | 10:38 AM
ZGPhoto's Avatar
Almost every 03 that was in the range is either fixed or dead by now.
Old Feb 20, 2013 | 10:43 AM
MC04DII's Avatar
Originally Posted by John Biggs
I will check the oil pump and see if it needs to be replaced. I'm hoping that by now with a 145xxx that it will have had most of its problems already and things have more than likely been replaced. The heater core gets no heat at all but I can feel warm coolant in the lines running into the fire wall. I am hoping that its plugged up and not something more sinister. The D2 has full coolant to my knowledge but I have only checked the level when I first bought here last week. Thanks for the info everyone.
Do you see any gold or copper looking flakes in the coolant? Someone may have used a stop leak on it which can and will plug the heater core.
Old Feb 20, 2013 | 10:50 AM
Dave03S's Avatar
Rather than pulling the front cover and checking the oil pump rings consider doing a pressure check... with a mechanical oil pressure gauge. @ idle and 2000 rpm both cold and warm.
If things look good all around then save yourself the time of taking things apart and putting them back together.
Save the front cover removal for when you want to service the timing chain, etc.
Run33
May 11, 2015 09:43 PM
Dwill9578
Oct 30, 2012 03:52 PM
n330jex
Sep 16, 2012 03:34 PM
bagocheetohs
Mar 28, 2011 07:38 PM
ctcnewton
Feb 18, 2006 12:32 AM
