New user/ coolent leak
Old Jul 31, 2012 | 11:59 PM
jeffysrover's Avatar
Default New user/ coolent leak
Hi today I learned my 2000 landy D2 has a spraying leak from the coolent on the drivers side where two small hoses come to meet.. It starts over heating if I drive it 5 miles now my question is do I need a new hose or new block where the hoses meet or can I get a sealent for it, or just tighten it? That is the best I can explain it. Thsnk you in advance.
Old Aug 1, 2012 | 12:09 AM
JohnKimble's Avatar
Are you talking about the two small hoses near your throttle body?
Old Aug 1, 2012 | 01:14 AM
jfall's Avatar
Snip off about 8mm on each and remount.
You may need to get a new hose clamp as those hose clamps are pressed on.
IF still leaking, you will need a new throttle heater unit.
Old Aug 1, 2012 | 04:45 AM
see Throttle Body Heater Plate Kit (Genuine Part # MGM000010) | Land Rover And Range Rover Fuel System Parts
And bypass (hose to hose with double male splice from parts store) or deal with it promptly, you will be lucky if overheating has not damaged engine (head gaskets, slipped sleeve). By overheating, I mean well above 50% on the gauge. If at end of scale or red light on, very bad sign. If you plug in an Ultra Gauge, you can watch that temperature and react before the factory gauge even goes off normal.
Many Discos are in the salvage yard because someone drove them when hot, thought they could make it to the next exit, or back home, etc. A case of bottled water in the cargo area is cheap insurance. Distilled would be better. It removes the temptation to keep driving before dealing with overheating.
Attached Thumbnails New user/ coolent leak-ultra-gauge.jpg   New user/ coolent leak-p1120320.jpg
Old Aug 1, 2012 | 08:21 AM
Make sure once you repair the t/body pre-heater hose leaks that you bleed the system or you will over heat your engine.
Old Aug 1, 2012 | 11:06 AM
jfall's Avatar
OK here is your homework assignment:
1) Bypass or fix throttle heater as per Savanna.
2) Bleed system as per Mike
3) Avoid engine damage by dropped sleeve or bad head gaskets.
You just don't want to get to step #3.
So, this assignment is due now.
RKW
Jan 4, 2014 12:05 PM
Jayseal22
Nov 27, 2010 12:21 AM
SpyderMan1964
Feb 23, 2010 07:14 PM
Tropical Disco
Oct 27, 2009 12:52 AM
jdthmpsn
Mar 5, 2007 10:58 PM
