Newbie owner of '00 Discovery 2 with leaks. Need tips and help.
Old 07-28-2019, 08:11 AM
jastutte's Avatar
Originally Posted by shanechevelle
1. What state are you in?
2 park the truck on a hill, front up and bleed it that way. Open the bleeder and add until it comes out. Squeeze your hoses back and forth so the air moves.
3.pull your plugs and post a pic.
^^ do this.
Old 07-28-2019, 08:04 PM
Ivan_Drago's Avatar
Texas. Hot as hell this week.
I will do that next week when I get back in town. Will post pictures of spark plugs and what ever codes showed up. I have the phone app but my mechanic has the real deal.
Old 07-28-2019, 10:27 PM
Why not pressure test the cooling system with a simple tester instead of guessing
how do you know it’s overheating ?? Are you going by the dash gauge ???
Old 07-28-2019, 10:30 PM
rented a powerbuilt coolant pressure tester from Autozone. Low and behold the BMW #5 cap fits perfectly.
you neec this
Old 07-29-2019, 10:23 AM
Ivan_Drago's Avatar
yes, gouge hit red zone in matter of 5 minutes.
Old 07-29-2019, 10:29 AM
jastutte's Avatar
get an OBD2 dongle and a free app that will give you real time temps.
the dash gauge is fairly useless. best case scenario you may be getting false overheat readings from it.
regardless, the dash gauge is not linear and only reads about three temps, Cold, Operating temp and Overheat.
Old 07-29-2019, 05:12 PM
Ivan_Drago's Avatar
Hmmm, could it be faulty gauge than... It did shut off the car until it cooled off a bit. I couldn't start it for few minutes after it hit red zone and I turned the engine off.
I have the phone app and OBD2 dongle, but it wasn't plugged in at the time. Like I said, my plan was to bring it home since we tested it for 20 minutes 2 hours prior.
Thanks for your help, guys. I will report on my progress once I get back in town next week.
Gonow
Build Threads
13
03-01-2019 10:51 AM
Draayer
04-25-2011 06:39 PM
XxRoverAllOverxX
10-26-2010 05:28 PM
moonman
09-28-2009 09:42 PM
psabatinojr
08-13-2008 09:41 AM
Quick Reply: Newbie owner of '00 Discovery 2 with leaks. Need tips and help.
