Newbie questions (just a couple)
Old Jun 29, 2019 | 09:35 PM
ezragray's Avatar
4wd High
Default Newbie questions (just a couple)
I have access to 2 salvage D2s ('01 & '02) for a limited time; I'm wondering about a couple of different components:
1) Viscuous fan: These older fans have an outer plastic band connecting the blades. My 2004 doesn't. Is there any advantage of one type over the other?
2) Oil cooler radiator: Would it be worthwhile to install this? I'm about to change my water pump so I'll have everything apart.
I only got my 2004 in April. Luckily, I found this forum right away & it's shepherded me through a rapid-fire "greatest hits" medley of D2 woes!
So far I've addressed:
* CPS to fix the no-start condition that got me an enviable purchase deal.
* Rattling cylinder liners: pinned the liners and installed a gray 180° t-stat.
* A bleed tee which snapped off & quickly vomited entire contents of cooling system into the street.
* Tired plug wires. Swapped these out when I had the motor mounts out & the engine lowered for better access for the liner pinning. Also removed the intake plenum for access & replaced the coil packs just because.
* Fixed the ash/coin tray springs with zip ties.
* 3 amigos: Actually haven't dealt with this as they've only been for a couple of short visits, but I knew from you folks not to completely stress out about it.
So thanks! Y'all are awesome.
Old Jun 29, 2019 | 09:41 PM
redwhitekat's Avatar
I would take some window motors alternator sai pump abs unit etc forget fans and clutch’s
btw who pinned and how much for the liner job
Old Jun 30, 2019 | 03:33 PM
Discorama's Avatar
I think so. I measure oil temps before the filter of 240F while coolant temps are 190F. That's at least a 50F temp difference within the block and I wonder if that is healthy, as well as the 240F oil temps, considering oil will get even hotter on engine parts (engine oil starts to break down at 270F). I haven't done this yet on my 2004 D2, but consider installing an engine oil radiator. First I need to find the parts, the lines/hoses are hard to get.
I you have a set of lines left over, I am interested in.
Old Jul 1, 2019 | 06:34 PM
Extinct's Avatar
Early fans are prone to cracking, go for the later one.
Get the trans cooler, its actually larger in surface area than the oil cooler. Drill a hole in the non-screw end and use a screw to hold it on.
Get the door lock motors and sunroof motors, you will wind up needing those.
Good to have:
ABS sensors
SAI tubes
PS pump
Front driveshaft
Horn buttons
Old Jul 2, 2019 | 03:22 AM
JUKE179r's Avatar
Check the gearbox on the '01 since it might have the nipple for diff lock and not the linkages.
You can pull it, and sell it for some money for other Disco parts.
usaf_disco
May 20, 2017 11:42 AM
Big Jim Swade
May 15, 2017 06:15 AM
cmb6s
Jan 31, 2015 01:37 PM
Savannah Buzz
May 1, 2011 08:56 PM
JBRIII
Jan 30, 2007 05:06 PM
