NGK ILZFR6011 Spark Plugs
Old Jan 4, 2018 | 03:49 PM
sayeedA's Avatar
Originally Posted by Best4x4
Crawl under it, and carefully check the 6 nuts securing the cats to the exhaust manifolds. They can sometimes work loose from vibration and all that is needed is a little lube, and tightening them up (DO NOT GO NUTS with the tightening or you could snap a stud off). The gaskets can fail, studs can break = exhaust tick under load, at a cold start up.
I lifted the truck took this video I dont see any visible leaks. You are probably right on the 6 nuts which I have yet to check.
Here is the video.
Old Jan 4, 2018 | 03:54 PM
Friday Night Disco's Avatar
I had a massive leak on the drivers side cat that you would not see unless you cut the heat shield away. Mine did sound slightly different but, hard to tell with you tube.
Old Jan 5, 2018 | 05:18 PM
Big Jim Swade's Avatar
I've got Bosch Platinum's in my 01 for the last 4 years and haven't had any issues.
Old Jan 5, 2018 | 06:07 PM
EasyDoesIt's Avatar
Originally Posted by Frank4
I have had issues every time I stray from the Champions. E3's, NGK the list goes on. I am sure others have had 10mpg and 30HP gains. Speak up!
I'll bite.
I'm getting 16-17mph on easy road trips going 55-65mph. Using 8mm Wires and NGK G Power Spark Plugs BKR6EGP.
Not sure how much of it has to do with plugs/wires, all the other maintenance i've done, or the gearing/tires. But I got the MPG on two separate road trips.
Old Jan 6, 2018 | 08:08 AM
JUKE179r's Avatar
I’ve got the NGK Iridium IX plugs (#3764) in Myrtle for the past year with no problems.
It’s known not to adjust the gap on the Iridium plugs because they come pregapped and people can break the thin electrode tip. But I’m glad I did check the gap on my plugs and carefully adjusted them. The NGK plug’s gap measurements straight out the box ranged from .032” to .055”.
Old Jan 6, 2018 | 09:07 AM
CollieRover's Avatar
I put in NGK Iridiums, cannot find the exact model at the moment, but did have to gap them. There is a video on their website on the tool to use. I was a bit worried, due to the iridium having a tendency to break, but the gapping tool never touched the tip.
I put in new Intermotor coilpacks, Kingsborne 8mm wires and the plugs. They are working great so far.
OffroadFrance
Off Topic
Jan 14, 2015 04:56 PM
archaeology_student
Jul 15, 2013 11:05 AM
Danny Lee 97 Disco
Nov 12, 2011 12:27 PM
ThorsDiscovery
Oct 23, 2011 06:31 PM
JRdisco1
Apr 15, 2006 11:43 AM
