nissen radiator
radiator arrived on monday. today i finally had time to install it. went in pretty smooth. everything in order. one thing im concerned about is:
is bottom hose suppose to get hot like the top? because when i checked it, it was cold.
any input would be helpful thanks
Tranny radiator is still there.
Just a tip to save some cash. If your radiator is not broken but just clogged with crud and limescale I have used this stuff on my D2 and Pajero. I leave it in for up to a week during the spring/summer (or a time when any freezing or frost is highly unlikely) with no stat then drain down, flush out (backflush) then refill with antifreeze containing an inhibitor. You would be amazed to see the crud that flushes out. The central heating cleaner is safe, they say, with all metals and seals probably because the same metals and seals appear in an automotive cooling system as well.
No Nonsense Central Heating Cleaner 500ml | Cleaner | Screwfix.com
Evian
Sep 10, 2005 01:39 AM
