nissen radiator
Old Mar 3, 2014 | 04:53 PM
  #21
jfall's Avatar
Which cooler was omitted for the 04?
Oil or trans.
And why did LR decide to omit the cooler?
Cost savings? or they just moved it elsewhere?
Never owned an 04 and it is a different beast than an 01 in many ways.
Old Mar 5, 2014 | 05:32 PM
  #22
joeyzaza's Avatar
7th Gear
radiator arrived on monday. today i finally had time to install it. went in pretty smooth. everything in order. one thing im concerned about is:
is bottom hose suppose to get hot like the top? because when i checked it, it was cold.
any input would be helpful thanks
Old Mar 5, 2014 | 05:46 PM
  #23
d7sec's Avatar
Oil or trans.
Oil cooler. Somewhere it was said new synthetic oils are holding better. Actually, here https://landroverforums.com/forum/di...e2/#post339471
Tranny radiator is still there.
Old Mar 5, 2014 | 05:48 PM
  #24
d7sec's Avatar
No, it should be warm, if your new radiator is actually cooling. IMHO, it works...
Old Mar 5, 2014 | 06:31 PM
  #25
OffroadFrance's Avatar
Just a tip to save some cash. If your radiator is not broken but just clogged with crud and limescale I have used this stuff on my D2 and Pajero. I leave it in for up to a week during the spring/summer (or a time when any freezing or frost is highly unlikely) with no stat then drain down, flush out (backflush) then refill with antifreeze containing an inhibitor. You would be amazed to see the crud that flushes out. The central heating cleaner is safe, they say, with all metals and seals probably because the same metals and seals appear in an automotive cooling system as well.
No Nonsense Central Heating Cleaner 500ml | Cleaner | Screwfix.com
Lord Wert
Aug 6, 2013 04:39 PM
SARAH1
Freelander
Oct 30, 2005 12:05 AM
Evian
Sep 10, 2005 01:39 AM
Rcraig
Aug 4, 2005 10:11 PM
nickvillaume
Jul 19, 2005 01:52 PM
