No blinkers or hazzard lights
Old Jan 4, 2014 | 04:45 PM
sstevensonm's Avatar
Default No blinkers or hazzard lights
All of a sudden my blinkers and hazzards don't flash. When u turn them on they will flash once and then nothing. Any suggestions
Thx
Shaun
Old Jan 5, 2014 | 08:24 AM
The RAVE has electrical schematics in color. They point to the relays and IDM module that is part of the "electronic" backside of the fuse panel. If testing indicates a new one, a boneyard or a dismantler like Paul Grant would be better price than stealership.
The IDM module will resync with the BCM if key is left in position 2 for about 10 minutes.
But check all fuses involved first. Could also be the BCM which is a more complex problem. It needs a shop level computer to resync with ECU and odometer, etc.
Old Jan 6, 2014 | 12:15 PM
SuperSport's Avatar
Do these not have a normal flasher like the old vehicles did? That's a super easy and cheap fix if so.
EDIT: I'm reading RAVE and it appears it may not... Doh! Also, FUSE #14 in Engine Compartment seems to control the flashing.
Old Jan 7, 2014 | 08:14 PM
Default Thx
Thx Supersport and Savanna it was the number 14 fuse
Jenniefer
Sep 15, 2014 11:45 AM
Spencerfitch
Jun 16, 2010 06:00 PM
kumbhani123
Nov 17, 2009 05:36 PM
JimScream
Nov 29, 2008 02:09 PM
Rover Reaver
Nov 2, 2008 12:23 PM
