Sponsored by: CARiD
Brake lights and rear blinkers wont work
Old Sep 5, 2014 | 11:16 PM
Jenniefer's Avatar
Exclamation Brake lights and rear blinkers wont work
I bought my 2001 land rover discovery s2 about a year ago, since then i have used these forums allot to fix and diagnose a few problems with it. I love these forums they are so helpful and everyone on here seems really nice but have never had to post to them until now.....
Today as i was driving my kids to school i noticed that my blinkers were clicking really fast and the blinker lights were flashing faster than usual so i checked to see if my blinkers were working, they were not. My bother in law is pretty good at fixing cars so he looked at it for me and realized that the brake lights were not working either. He checked everything he could think of, fuses, bulbs, things like that but nothing he found fixed the problem. We have to drive 1000 miles back to utah from montana in about a week and this is our only car so any help or advice that can be given would be amazing. Thanks in advance.
Old Sep 5, 2014 | 11:19 PM
Jenniefer's Avatar
even something that i could rig just to get the lights to work would be good anything to get them working so i dont get a ticket
Old Sep 8, 2014 | 04:00 AM
abran's Avatar
The rapid blinking usually means you have a bulb out.
But since that was checked, there is a small plunger type switch at the brake pedal. You need to remove the lower kick panel(black color) under the drivers side to get to it.
This switch is what actuates the brake lights. Check that. Also search in the forum for brake switch.
Weird that blinkers and brakes are not working though. Post your issue in the Discovery 2 section and you will get a lot of replies.
Old Sep 8, 2014 | 08:34 AM
drowssap's Avatar
i would also post under the dII section but i think the brake light switch may have to changed out
Old Sep 12, 2014 | 12:28 PM
roverdoctor11's Avatar
4th Gear
Default Lights
If bulbs are good, could have a bad socket or connector, I would check for power at the bulbs, Is it on one side only or both? The brake switch wont cause the blinker issue
Old Sep 12, 2014 | 10:37 PM
LRScot's Avatar
Which bulb is blinking? If the front is blinking then the back one is out. If the back one is blinking the front one is out.
Old Sep 15, 2014 | 09:24 AM
dougwrench55's Avatar
If in fact all the fuses are good the only common denominator between the turn signals and brake lights is the turn signal switch in the steering column. Just a thought, have you replaced any rear bulbs recently?
Old Sep 15, 2014 | 11:45 AM
drowssap's Avatar
did you check the flasher units inside the truck under the wheel?
sstevensonm
Jan 7, 2014 08:14 PM
Spencerfitch
Jun 16, 2010 06:00 PM
kumbhani123
Nov 17, 2009 05:36 PM
JimScream
Nov 29, 2008 02:09 PM
