No heat blowing from the main vents
Old Jan 28, 2013 | 09:01 PM
JipcQueen's Avatar
Post No heat blowing from the main vents
I'm nursing a 2003 DiscoII and need some guidance on troubleshooting steps regarding my heater. When activated, I get no heat from the vents located on the dash, but only get heat coming from the leg and winshield areas no matter which power setting is selected.
I searched previous threads, which suggested accessing the blower fan by removing the glove compartment and accessing the fan for cleaning. This is what I plan to do. However, since there's heat blowing out from the leg and the defroster vents, that tells me that the blower fan is working. Perhaps there is something obstructing airflow to the main vents in the dash instead. Any knowledge and advice is much appreciated. Thanks for your attention.
Old Jan 28, 2013 | 09:14 PM
jhill15's Avatar
Check your coolant level, if its too low then the heat will blow cold, fill it up and mark a line with a sharpie to see if Theres a leak
Old Jan 28, 2013 | 09:19 PM
JipcQueen's Avatar
Thank you for the quick response. My coolant level is solid. I've been checking it and topping it off as needed. I do have heat...it's just not blowing out of the main vents aimed at the driver and passaenger. I only get heat from the leg area and the windshield defroster areas. The heat just seems to ooze out of the main vents.
Old Jan 29, 2013 | 01:03 AM
See attached pages from the RAVE (factory shop manual) - cable 12 I believe. More in the RAVE, your free download awaits.
File Type: pdf
mkimerly
Sep 8, 2014 05:27 PM
mkimerly
Sep 6, 2014 04:50 PM
A5scott
Jun 27, 2012 07:53 PM
Miwo
May 4, 2011 08:40 AM
Eak69
Apr 4, 2010 11:52 AM
