03 D2 blower for heat and A/C vents
Old Jun 27, 2012 | 11:18 AM
A5scott's Avatar
Default 03 D2 blower for heat and A/C vents
So, when I turn the heat or A/C on, and turn the fan on 2 or higher, I hear kind or a restricted air flow rumbling sound, that seems to be coming from the other side of the fire wall. The noise is subtle on fan position 2, and louder on 3 and 4... full blast fan. heat and A/C working normal... blowing hot and cold air respectively... just noisy so I keep them on 1
any ideas?
thanks
scott
Old Jun 27, 2012 | 11:26 AM
nychaze's Avatar
Most likely there is something in the fan, dust, leaves, nuts or whatever else got sucked in over the past 9 years. Pull the black panel out below the glove box to gain access to the fan. Take the fan out and clean it up, if there are still noises the bearings are probably shot and you will need to replace the fan (call Paul Grant...his contact info is DiscoMike's signature) or look on ebay.
Also, for preventative maint. open the hood and see what the intake filter looks like, if its still even there. It runs along the back side of the engine compartment.
Here is the replacement or make your own:
Filter Pollen (Genuine Part # JZL100120) - Land Rover pcv & pollen/cabin filters from Atlantic British
Old Jun 27, 2012 | 11:30 AM
A5scott's Avatar
ok great Thank you nychaze!
scott
Old Jun 27, 2012 | 06:22 PM
br0keit's Avatar
Yes its probably crap in your fan. You'll be surprised at how much is in there too. for easier access take off the glove box, then take out the 3 bolts on the fan right under it, pull it out and you'll see your issue. Fix it before using it too much as you can blow your power transistor running it at high load too long.
Old Jun 27, 2012 | 07:53 PM
A5scott's Avatar
Thank you Br0keit...
trying to stay on top of things before they cause more problems
scott
cappedup
Dec 23, 2014 11:55 AM
JipcQueen
Jan 29, 2013 01:03 AM
Miwo
May 4, 2011 08:40 AM
Eak69
Apr 4, 2010 11:52 AM
99LRDisc
Apr 26, 2009 06:25 PM
