No low gear. N,R, or 3 showing
Old Dec 13, 2016 | 07:16 AM
  #21
jrwalk1651's Avatar
Originally Posted by mln01
How did this turn out?
install went fine, but I'm still getting the same readout. Either this is another bad switch or the problem is elsewhere. I took it to my Land Rover guy to read the tranny codes and he said the switch was showing the correct gear in his system and after adjusting the linkage and the switch still couldn't get it to show on the cluster. I'm going to take apart the center console and see if it may be a bad shifter assembly or the wiring is messed up in there. Only negative is it's well below freezing here in Chicago so I've been slow to get around to things.
Old Dec 26, 2016 | 10:45 PM
  #22
jrwalk1651's Avatar
Just a bump here. Took the center consol out and everything seemed fine. I'm at a loss here can't figure it out....could this be a BCU error? Is there something I'm missing here?
Young
Aug 29, 2011 07:16 AM
philander
Aug 19, 2011 04:20 PM
skatelove303
Jun 19, 2009 11:00 PM
sfxgamer
Nov 28, 2007 07:18 PM
sfxgamer
Aug 17, 2007 09:05 AM
