No oil pressure after engine swap and what I have tried so far
Old Oct 18, 2018 | 10:46 PM
  #61
Best4x4's Avatar
Awesome!
Old Oct 19, 2018 | 02:42 AM
  #62
The Deputy's Avatar
Good news. But, this whole topic will go down in history as the most unforeseen issue we've probably ever run across...a missing drive gear for the oil pump. Even l was getting a bit stumped, when you showed the pictures of the inner, outer oil gears and cover...they looked so good. Everyone was talking about priming issues, and l knew that wasn't the case...because it supposedly ran just prior to removal and truth be told...a little oil on the gears is enough to rebuild oil pressure...this whole Vaseline thing is almost borderline ridiculous to me, l've never heard of, seen or used it in 40 years of being a mechanic. White lithium gease or heavy assembly oil is a much better product for priming a brand new oil pump assembly. Why someone would use a non mechanical type product to prime a mechanical item is beyond me...especially...when there are so many other correct products.
​​​​​​​Just pull fuse 14 in the drivers compartment fuse box, turn over engine until light goes out or until you are satisfied...install fuse and start her up.
Anyhow, keep up the good work!
Brian.
Old Oct 19, 2018 | 06:09 AM
  #63
R0VERGUY's Avatar
Way to stick it out. Good to hear you got it up and running.
Old Oct 19, 2018 | 08:15 AM
  #64
Best4x4's Avatar
I saw the missing middle gear but figured it fell out & just wasn’t in the pics I’ve seen & had several do it in the past. Still a wild thing to have happen!
Old Oct 19, 2018 | 08:17 AM
  #65
The Deputy's Avatar
Originally Posted by Best4x4
I saw the missing middle gear but figured it fell out as I’ve seen & had several do it in the past. Still a wild thing to have happen!
Yeah, I just assumed he removed it. Mine fell out on the 03, while removing, too.
Brian.
Old Oct 19, 2018 | 10:32 AM
  #66
T-rex's Avatar
SWEET! . . . on to the next problem!
Old Oct 19, 2018 | 11:08 AM
  #67
Richard Gallant's Avatar
Outstanding, glad you are up and running.
Old Oct 22, 2018 | 08:11 PM
  #68
No Doubt's Avatar
Talking
Originally Posted by MtnCrk
WE HAVE OIL PRESSURE!!!!!!
light came on ... then flickered .... then engine got quiet and purred .... light went out.
THANKS to ALL who helped. I have learned a lot on this project.
Wow!
Charlie_V
Jan 6, 2016 01:41 PM
velija
Mar 11, 2014 01:59 PM
ArmyKen
Apr 10, 2011 09:16 PM
bigugly82
Aug 21, 2007 04:34 AM
aerokurt
Dec 3, 2006 06:00 PM
