Oil Pressure
Old Aug 16, 2007 | 01:25 PM
bigugly82's Avatar
Default Oil Pressure
I've changed the oil in my '03 Disco twice. Both times I've put oil in the filter when I installed it. But my question is. Both times when I've started it my oil pressure light has never come on. Should I be concerned that it's not functioning properly?
thanks
-ugly
Old Aug 16, 2007 | 01:42 PM
jdelp's Avatar
Default RE: Oil Pressure
Nope, that's normal. You should never see the oil pressure light after an oil change...unless you forget to put oil in the crankcase! I don't even prime the oil filter, although it makes sense. Unless you've got a bad oil pump, that 1/8 second it takes from pickup to the motor is insignificant - especially since you still have oil lingering in there from having just drained it.
Old Aug 16, 2007 | 01:44 PM
bigugly82's Avatar
right on, thanks.
Old Aug 16, 2007 | 08:37 PM
Do make a point of filling your new oil filter before you install it so you don't drive start your old Rover, especially 03 since they have been a little prone to oil pump failure issues.
Old Aug 21, 2007 | 04:34 AM
mordor110's Avatar
Hopefully your oillight is ON when the motor is OFF but the ignition is ON?! To signify that it is working.
eaglewing
Apr 16, 2011 11:06 AM
Snafu / Disco Fries
Feb 24, 2011 09:10 PM
lipadj46
Oct 17, 2010 06:34 PM
tito5590805
Oct 4, 2010 09:11 AM
DooDer
Jan 12, 2010 10:46 PM
