No power after new battery and alternator
Old Jun 24, 2023 | 07:52 AM
mollusc's Avatar
Yes, that is the 150A. I think it should have power constantly so checking for voltage on both sides will tell you if it is blown or not (one side hot to the battery will always have power, regardless of the state of the link).
Old Jun 24, 2023 | 09:29 AM
Best4x4's Avatar
Lord I answered this in back in 2016 lol.
Old Jun 25, 2023 | 11:44 AM
signalMTB's Avatar
Tested the alternator, reads 12.13V when running. Same reading at fuseable link.
The battery light randomly went out, retested and it showed 14.55V.
Battery light is back on it reads 12V again.
bad alternator?
Old Jun 25, 2023 | 04:34 PM
Harvlr's Avatar
It’s probably a bad alternator. Take your voltage reading with your positive lead right at the alternator main terminal and the negative on the alternator case. If you read it at the battery, and you have poor connections or wires, a good alternator could read low. Also if the field wire is broken, the alternator will not get excited until you rev it a little, in which case a good alternator would read low at idle (until it produces enough voltage on it’s own to excite itself).
Old Jun 29, 2023 | 04:53 AM
signalMTB's Avatar
Pulled the alternator and it’s branded VALEO with a LAND ROVER tag. The tag looks OEM but google tells me valeo isn’t the original
Old Jun 29, 2023 | 08:34 AM
mln01's Avatar
Valeo is (was) the OEM supplier.
Old Jun 29, 2023 | 01:25 PM
signalMTB's Avatar
There's a difference it seems in OEM supplier and Genuine Equipment ... the genuine equip is $1200, the valeo is priced at $350. The "supplier" and "genuine" has always confused me
lohnjouis
Feb 4, 2023 10:04 PM
Jeff Blake
Aug 27, 2017 01:44 PM
jastutte
Jun 12, 2017 09:01 AM
Bad_Company
Jun 27, 2013 01:21 PM
tailchaser0527
Feb 20, 2008 09:20 PM
