no start m and s lights flash good spark, starting fluid wont even fire
Old Sep 23, 2014 | 10:56 AM
  #21
importdave's Avatar
Thank you. I will do that. I didn't realize the pump might shut off if pressure is achieved. Most European cars don't have a mechanism for that. They simply run the pump constantly and return all the fuel that pushes past the regulator. I'm going to lift up the rail tonight to insure i'm getting proper fuel volume
Old Sep 23, 2014 | 11:18 AM
  #22
drowssap's Avatar
another possibility of why the truck will run but then dies down the road, how about the fuel tank vent? i think if it were blocked it could possibly cause an issue like this, just a guess though.
Old Sep 23, 2014 | 11:21 AM
  #23
Motorhead1's Avatar
Fuel "volume" or not, I think if you have 50 psi will cranking, the engine should at least start? Back when you said it started with the plenium off, are you sure you dont have an air intake issue? maybe something blocked in the air box? Hmm.. maybe a rag sucked in somewhere? Seen it before
Old Sep 29, 2014 | 02:53 PM
  #24
importdave's Avatar
Solution! Bad IDM! Swapped oue from another rover. Started immediately
ckayak2
Apr 8, 2018 05:00 PM
D1V8OZ
Feb 8, 2015 07:50 AM
Happy Chef
Sep 1, 2012 10:31 AM
Anglacon
Jul 13, 2012 09:08 AM
