Noise when starting
Old Jul 27, 2006 | 01:13 AM
jboy's Avatar
4th Gear
Default Noise when starting
I have a 2002 disco 2 that has a intermittent dull grinding sound coming from the drivers side when starting.The only thing i've checked is the a/c drains to make sure they are not stopped up.Can anyone shed some light on this noise?
Old Jul 27, 2006 | 10:24 AM
Default RE: Noise when starting
Well, it won't be water plugged up by the old nipple drains, that is for sure.
You need to crawl under wheile someone is trying to start the engine and see where the noise is coming from, then get back to us.
Mike
Old Jul 27, 2006 | 10:25 AM
Landzu's Avatar
Your starter may be the noise maker.
This may mean its almost time for a new one.
Try to get it checked out before it leaves you out some place.
Mike
Old Jul 30, 2006 | 08:54 PM
jboy's Avatar
4th Gear
Mike,
I checked the starter but it seems to be fine and it's also located on passenger side.This noise only happens after the disco has set for a while before starting.It seems to be coming from under dash of drivers side.
Regards
Jude
lazerbrains
LR2
38
Aug 9, 2023 07:54 PM
hhalimi
Jan 20, 2012 11:06 AM
anonimaus
Jan 13, 2010 07:21 PM
apcollin
Dec 3, 2008 11:58 AM
mowthat
Feb 5, 2007 11:25 PM
