Noisey Brakes
My 2001 land rover just got new land rover grade pads but they squeel like a b***h. I've seen that others on here sugest the Akebono ceramic pads, besides changing the pad all together, is there anything else that might be causing the squeel? Braking is smooth and solid, the land rover pads feel great.
squeal is usually caused by the pads vibrating against the caliper. Did you lube the caliper slide pins and lube where the pads contact the caliper?
Brake Lubricants: Brake and Front End
Well, technically you can get the rotors done. Even the rave has specs for a "service limit" of the rotors:
Front disc minimum thickness:
⇒ New 24.9 - 25.1 mm (0.980 – 0.988 in)
⇒ Service limit 22.0 mm (0.866 in)
Rear disc minimum thickness:
⇒ New 12.5 – 12.7 mm (0.492 – 0.500 in)
⇒ Service limit 11.7 mm (0.461 in)
As for noise, it has been said and I'll say it again, did you grease where the pad contacts the caliper?
